As you can see in the for sale section I have some trouble uploading different pictures. Even when I try it in different posts it changes the previous message. I tried from different devices but all have been IOS devices.
Onno The first posts look OK to me. Were you not able to see the pictures initially, then they appeared after? I need to understand the precise problem. Please add a post with a picture to this thread using your IOS device but do not make any posts afterwards until I have seen the result. Nick
Yep that is the problem. If I upload 2 pictures in succession both will show the last uploaded picture. Only when I wait several hours can I upload a picture without replacing the first. I have fixed it using my work laptop (windows) but it might not always be available to me and for a quick upload from my phone this does not help.
I must admit I have not tried a different browser on my I pad, I'll test that here
OK, I see the problem. For some reason, each successive image upload using iOS is saved with the same file name. Hence later images overwrite earlier ones. Now I can try and search for a solution. Nick
