Malcolm Bailey
301 Posts |
Posted - 14/10/2017 : 09:57:45
In my endeavours to put my car back to its original specification I am looking for a Rotax AT 174 dynamo in any condition, working or not. If anybody out there has one lying in their workshop I would be delighted to hear from them. Many thanks Malcolm |
bloodysalmon
Spain
1482 Posts |
Posted - 14/10/2017 : 10:52:38
you'll be lucky Malcolm, but you may try Chris Wallis ...
Chris Blood D0407 & F0753 |
KJ1592
449 Posts |
Posted - 14/10/2017 : 16:34:53
Barry Walker had one on his stall at Beaulieu. Not sure if he sold it. |
1481 Posts |
Posted - 15/10/2017 : 12:18:17
I expect you already know Malcolm, that whilst AT174s were fitted to K3s (and other K Types) and Ns and therefore quite reasonably could be assumed to be stronger than the Lucas DDS14, in fact the AT174 has a major disadvantage. The top one third of the casing incorporating the brush gear and top bearing was made of aluminium and therefore had a tendency after long usage to develop cracks. A few years ago a batch of bronze replacements for this part of the casing were available and I was lucky enough to get one from S&V. It would be wise to try and get hold of one of these parts if they are still available.
1949 Posts |
Posted - 15/10/2017 : 14:43:59
Hello Colin. Interesting to read that the uppermost section of the AT174 dynamo was made of aluminium because I well remember my first N type way back in 1963 definitely had a bronze section, I am now wondering what the likely explanation would be for that. Any ideas?
Regards, Chris. |
Malcolm Bailey
301 Posts |
Posted - 15/10/2017 : 19:50:27
Thanks for all your comments. I shall follow up on the leads for a Rotax AT 174. A letter from MG Car Company to the owner of my car in 1947 states "the correct dynamo for the "NA" was the AP174 and the DDS 14 was normally fitted to the 'PA' Type" The car was is currently fitted with the DDS 14 (presumably the cause of the enquiry to the MG Car Co in 1947) hence my search for an AP 174. I was aware of the aluminium top Colin and your suggestion re the bronze top is well received provided I can source the dynamo itself. I would be prepared to trade in my current working dynamo which has been adjusted to operate on two brushes.
Thanks again for your responses Malcolm |
Jamie
Canada
218 Posts |
Posted - 15/10/2017 : 20:07:49
My understanding is that the AT 174 brush housings were originally aluminium and found to be too fragile so later ones were bronze. I have an aluminium one in three pieces which indicates that to be the case. I also have two different bronze replacements, one sourced from S&V, the other from Ron Grant. Both look to be much beefier than the original but are clearly different castings. I can post pictures if needed.
Jamie |
kjrj
136 Posts |
Posted - 17/10/2017 : 16:35:59
No doubt this Triple-M novice is teaching seasoned experts how to suck eggs, but just to note that the AT174 has a thicker shaft than the DDS14 and therefore needs a different bottom gear.
Kevin
Kevin Jones Letchworth, Herts NA0950 |
Malcolm Bailey
301 Posts |
Posted - 17/10/2017 : 20:35:58
Thanks for your comments Jamie and Kevin. I always knew I was searching for "hens teeth" and if I found one it was going to cost. It was worth a try. Malcolm
1481 Posts |
Posted - 18/10/2017 : 09:57:54
There are probably quite a lot laying about - all with broken aluminium housings ! Keep trying Malcolm. The larger gears were available through S & V a while back. If there is sufficient interest I wonder whether a new batch of bronze ones might be in order. The trick is likely to be the whereabouts of the mould or moulds from which the most recent batch were made. Mike Allison had these made but he passed the moulds on to someone else, who hasn't yet admitted to having them !
Edited by - Colin Butchers on 18/10/2017 10:03:18 |
O.Thomas
755 Posts |
Posted - 18/10/2017 : 10:24:30
I have the patterns Colin and they have been passed on to Mike D , who is hopefully on the case! |
Malcolm Bailey
301 Posts |
Posted - 19/10/2017 : 16:06:59
Thanks to both of you for your helpful comments. In order to start the process I do need an AT 174 in need of recovery. Is there one out there lying neglected at the back of a garage? Malcolm |
1481 Posts |
Posted - 20/10/2017 : 11:18:14
Ah so - Ollie. Excellent news.
2138 Posts |
Posted - 20/10/2017 : 21:36:43
I have a Rotax AT174 on the shelf which I have recently had professionally rebuilt and is complete with gear. I took this unit off a car I was selling 15 years ago as it was incorrect for the engine.
I know these are fetching 4 figures now and I have turned healthy offers down in the past. Now may be the time to invest funds elsewhere possibly so if any needy enthusiast wishes to make me an offer I cannot refuse on this unit then they can email me privately if they wish
Richard
Edited by - Richard Hardy on 20/10/2017 21:37:58 |
Malcolm Bailey
301 Posts |
Posted - 21/10/2017 : 06:38:21
Rich, I have sent you an email Malcolm |
Malcolm Bailey
301 Posts |
Posted - 27/10/2017 : 11:00:34
I am still looking for an AT174. Is there someone out there that might have one in the back of their garage. Could be a fundraiser for them just in time for Christmas! Here’s hoping and thanks for looking. Malcolm |
