Ross Kelly
226 Posts |
Posted - 15/09/2018 : 01:21:22
Hi All, Would anyone know who may supply the parts shown in attached photo for preselector remote,
The Engraved Mixture plate The engraved Ignition plate Two of the control levers The brake adjustment system the is attached to the remote
cheers ross kelly
Edited by - Ross Kelly on 15/09/2018 01:22:02 |
paul55
Luxembourg
728 Posts |
Posted - 15/09/2018 : 07:29:06
Ross,
I got my brake adjusting wheel and assembly from Barry Foster, I think that the wheel itself is something from an 18/80 rocker box cover. I bought my preselector and remote from Tom Dark and it already had the plates,levers and internal workings fitted. You could try him.
Paul. |
Ross Kelly
226 Posts |
Posted - 16/09/2018 : 08:48:17
Thanks Paul,
I will try those you suggested again and see if I have better luck.
cheers ross
Andrew Fock
370 Posts |
Posted - 16/09/2018 : 22:48:25
Hi Ross,
Did the K3s have the mixture lever? They used a Ki-gas primer for starting.
Andrew
NA 0279 PA 1294 |
1949 Posts |
Posted - 16/09/2018 : 23:55:05
The K3 didn’t have a mixture control as pointed out by Andrew and the plate fitted here was a blanking strip, ( I.e. without the slot)
Chris |
Ross Kelly
226 Posts |
Posted - 17/09/2018 : 11:42:12
yes Andrew and Paul, you are correct a little less to fix.
cheers ross |
