Moth eaten
939 Posts |
Posted - 07/01/2019 : 22:11:57
I am looking for a missing oiler, which is a push in to fit a 6mm hole. Any relics would be welcome. Also any case screws, the small hex head with slot which are 3/16" BSF. I forgot to add that a DQH6A distributor which was sold to me had the wrong rotor fitted so that is another part I am looking for!
N.D.Willey |
Edited by - Moth eaten on 08/01/2019 06:29:21 |
bloodysalmon
Spain
1482 Posts |
Posted - 08/01/2019 : 10:05:26
do you mean one of these Nigel? Have you a photo of what you think the correct rotor arm should be for your L1 as I have a few to choose from?
Chris Blood D-type Salonette D0407, TC1472 TC2686 TC4245 |
george
862 Posts |
Posted - 08/01/2019 : 10:18:46
Nigel, Be aware that there are two different rotor arms that fit DF and DQ one is for the vertical exit and one for the horizontal. The diff is the length of the sticky out bit, I cant remember which is which but put the longer one in a cap meant for the short one and bang goes the cap[very expensive]. Geoff |
Moth eaten
939 Posts |
Posted - 08/01/2019 : 11:17:11
Thanks Chris, its a push in to the distributor shaft, no thread. And George thankyou, yes I am aware of this issue. Its a side exit as both are. The rotor was stuck onto the post and after pulling it off, it has side ways slop, so obviously wrong. I will have to look into sourcing the correct rotor. I have cleaned up the case screws and re indexed the flats closed up the burred slots and re filed them. Hrs of work.
N.D.Willey |
668 Posts |
Posted - 10/01/2019 : 05:50:24
I don't have one but I guess you are needing the ES33
Moth eaten
939 Posts |
Posted - 10/01/2019 : 08:04:58
Thanks Kevin, yes the ES33.
N.D.Willey |
