Home | Profile | Register | Active Topics | Members | Search | FAQ
 Sump suction filter gauze
 New Topic  Reply to Topic
Posted - 09/03/2010 :  11:55:49  Show Profile  Reply with Quote
I'm attempting replacement of the gauze, so far without success. Despite cleaning the surfaces with isopropyl alchohol the solder just forms balls & will not penetrate the mesh. I'm guessing that the surface tension of the solder is too great for the gauge of mesh? So far I've tried cored electrical solder with a gas blowlamp & wonder how others have tackled this job. Any advice would be much appreciated.
Posted - 09/03/2010 :  13:01:11  Show Profile  Reply with Quote
Assuming you are using brass gauze? I have sometimes found it can be reluctant to 'tin'. This can usually be encouraged by introducing something like a screwdriver (or a big pre-heated soldering bit) and pressing and rubbing the molten solder with it whilst still playing the flame. You will end up with a solder coated screwdriver (easily cleaned off). I have used this method sucessfully to overcome the effect you describe.
Edited by - kimber on 09/03/2010 13:01:59
Posted - 09/03/2010 :  14:43:55  Show Profile  Reply with Quote
Many thanks Andrew, yes it is brass & your screwdriver sounds a good idea. I'll try it after necessary family matters!
talbot
Posted - 09/03/2010 :  17:23:14  Show Profile  Reply with Quote
Hi Dave,
'had the same problem when I was repairing the oil strainer on my TD. The solution was to use "proper" soldering flux - Bakers Fluid and a soldering iron. Cored solder doesn't clean off oxide particularly well so the solder is relucant to "wet". Also using a flame you will overheat the gauze and again cause it to oxidise. Your only problem will be buying Bakers Fluid - it's not the thing you can get in B&Q.
Jan T
Horst Wendling
Posted - 09/03/2010 :  18:49:28  Show Profile  Reply with Quote
Hi Dave,
i cleaned the gauze by glass blasting first and had not a problem.
Use a gas soldering-iron or a big electrical. The probelm is, you make it realy hot.
Otherwise you test soldering fluid from a slater (roofer, tiler ?)or copper-tube soldering paste. At the end clean it very good with water or in a ultra sonic bath.
Horst
Posted - 09/03/2010 :  19:10:48  Show Profile  Reply with Quote
I use Fluxite Soldering paste, which I have had 'since Adam were a lad'. However you can still buy it from many different sources such as http://www.chronos.ltd.uk/cgi-local/ss000001.pl?RANDOM=NETQUOTEVAR%3ARANDOM&PAGE=SEARCH&SS=fluxite&TB=A&GB=A&ACTION=Search
If you make sure that everything is clean and you get the job hot enough, this has always worked OK for me.
Peter
Posted - 10/03/2010 :  10:29:16  Show Profile  Reply with Quote
Many thanks to all who have replied to my plea. I have some of those things you "have to do" but will shortly get back to it with all your suggestions. Fortunately the area supplied by Mike Dowley is such that I can throw away my first attempt!
Triple-M Register Forums © 2009 MGCC Go To Top Of Page
