Triple M Register
Triple M Register
 Annealing gaskets? A word of warning!
Previous Page
Page: of 3
Posted - 12/10/2018 :  00:55:07  Show Profile
Tommm,
You'll have to stop quenching your gaskets in the river
Ray White
Posted - 14/10/2018 :  00:35:32  Show Profile
Originally posted by Andrew Allen
I think you'll find silver is the best conductor of heat and electricity. Gold has better corrosion resistance and platinum better wear properties, hence its use for electrical contacts.
Andrew Allen
Yes, this is also the claim made for silver electrode sparking plugs (recommended for LPG conversions)
R. White
Posted - 14/10/2018 :  09:49:24  Show Profile
Ian,
Is there a metallurgical limit to the number of times a gasket can me annealed, assuming it is undamaged and otherwise ready to fit?
Posted - 15/10/2018 :  07:24:41  Show Profile
Simon
No. The work hardening - annealing cycle can be repeated indefinitely. The copper atoms have no memory.
The repeated oxide formation will, however, and over repeated cycles lead to a thinner copper gasket, but it would take many cycles and careless annealing to become noticeably thinner.
OD 6791
J3 3772
Edited by - Ian Bowers on 15/10/2018 07:26:30
Posted - 15/10/2018 :  08:03:48  Show Profile
Many thanks, Ian. I suppose the gasket may get thinner over time simply by being squeezed between head and block each time it's reused but that's likely to take quite a few iterations I guess.
Posted - 15/10/2018 :  11:05:54  Show Profile
All metals are, for all normal purposes, incompressible. They are not going to get squeezed around under engine bolt down, operating pressures and temperatures.
OD 6791
J3 3772
Edited by - Ian Bowers on 15/10/2018 11:06:25
Posted - 15/10/2018 :  11:21:01  Show Profile
So, to infinity and beyond, then?
roger cadogan
Posted - 16/10/2018 :  20:06:46  Show Profile
If anyone is interested in thicker copper gaskets for J engines I have some left over from a batch made from 1/8"copper at very reasonable prices.
Roger
Previous Page
This page was generated in 0.06 seconds. Snitz Forums 2000
