Hi, I am in need of an angle drive box for the cable from the gearbox to the mileometer for my NA. It is part number A 597 in the parts list. Unfortunately S & V has no stock. Thanks in advance
Good Morning Jos and Lew. I will be making more in the months ahead. New main bodies being cast at the foundry. I have enough to make 10 complete units. Hope this helps you out Jos. For those that have wonky original worn out bodies I can fit your original internals to a new body. Can make bits that are missing or damaged.
The angle drive box I need is attached to the gearbox and the cable goes into the box. So i think that the angle box needs to be threaded at both ends. Jos
