 Stainless steel tube
njnh
Posted - 21/03/2020 :  09:45:49  Show Profile
Does anyone happen to have some thick-wall stainless tube suitable for joining the J2 front cycle wing stanchions - ie the tube that runs horizontally across the front of the radiator? I think it is 5/8 OD. I can only find thin wall tube on the internet.
Nigel H
frederick wheeler
France
Posted - 21/03/2020 :  12:25:51  Show Profile
Hello Nigel,
You could try Durbin metal industries at Yate nr Bristol. They list stainless steel seamless tube ASTM A269/A213 in grade 316 or 304
316 being available in 16mm x 2mm wall 304 available in 5/8”x 16 SWG (1/16”). 16mm is only a few thou bigger than 5/8”. I am using 1.6 mm wall which is very rigid and up to the job. I suggest you phone first to see if they will supply a small quantity, then collect. The number to use for st steel is
01454 322668. Stainless comes in ground finish and will need polishing to look like chrome.
f wheeler
njnh
Posted - 22/03/2020 :  19:27:47  Show Profile
Thanks for this information Fred. I have seen some 1.6mm wall tube on the internet but I doubted whether it would be rigid enough.
Nigel H
Posted - 22/03/2020 :  19:58:12  Show Profile
Same here - 16mm x 1.6mm thick. Works just fine.
