Hi Paul, I may be able to help. Prior to Covid upsetting things I was able to make new ones.... at present cannot get brass castings.... working on that problem. However if you have a "distressed" old pipe I can retube it if the end castings are reusable. I can still make all the pipes that have nut and nipple ends and retube any others. I have retired from "climbing under other people's cars" but still happy to make oil pipes .... FOZ
thank you for replying foz i would like you to make one ,if possible as far as i know,the drain pipe is the only one needed. i have not yet got an old pipe,so the problem could be the brass castings
