751 Posts |
Posted - 14/06/2021 : 15:49:02
I am looking for a drawing showing this item, the sockets that go in the doors to take the hood frame. I can guess what it should be but I'd rather try and make it as near to the original as possible. Many thanks. I've looked in documents downloads or whatever it is called and can't seem to find any such information.Perhaps someone cleverer than I can.
John Cooper M 628 |
Edited by - Cooperman on 14/06/2021 15:49:53 |
bloodysalmon
1477 Posts |
Posted - 14/06/2021 : 18:02:35
these are the ones I made a few years ago now with S&V
Chris Blood |
1455 Posts |
Posted - 14/06/2021 : 18:14:09
You can't find any because the M didn't have them! The hood frame fits straight into the woodwork through the alloy capping. Same with the sidescreens. If owners fitted sockets then they were probably like the Minor - smooth sided but a tight fit with an off-centre hole for the frame. It sounds too crude to be likely until you remember the door "cards" were just leathercloth alone which was nailed on. Likewise the aluminium door and boot trims were nailed on not screwed. |
3040 Posts |
Posted - 14/06/2021 : 19:34:22
Ian, while I agree most M-types did not have side screens this factory picture shows a metal panel car which has sockets for them -
The list of extras includes Side Screens (Plus Fitting) for £2 2 0.
The hood frame appears to go into sockets in this factory picture.
This car has sockets for both hood and side screens.
1455 Posts |
Posted - 14/06/2021 : 20:25:55
Sam, thanks, not much doubt about that! With sidescreens I expect later owners just drilled holes in the door if they wanted sidescreens but clearly there was a socket for the hood right from the start. Are there similar pictures for early cars like John's? |
3040 Posts |
Posted - 14/06/2021 : 21:58:40
Ian from the look of things in this rainy picture these early M-type owners probably wished they had side screens.
But this car in the same wet line up has side screens.
This is 2M 371 which currently has sockets as seen below.
2M 371 appears to have had the same sockets when photographed in 1956 so there is a fairly good chance they are original.
1455 Posts |
Posted - 15/06/2021 : 09:22:40
So I'm completely wrong because even my car has holes large enough for sockets though a bit battered round the edges. I can only find one socket though. I'm puzzled by the hood socket - surely it must have been a larger size? 1/4" seems very small for the hood frame ends.
Now found a couple more, but which kind is right?
Edited by - Blue M on 15/06/2021 09:47:52 |
5942 Posts |
Posted - 15/06/2021 : 09:44:12
It’s interesting to have a look at the patent, the number of which is visible in the picture above.
668 Posts |
Posted - 15/06/2021 : 09:59:47
Simon, who took the patent out? |
5942 Posts |
Posted - 15/06/2021 : 11:06:05
Weathershields Ltd. and R.E. Morgan, October 1925
751 Posts |
Posted - 15/06/2021 : 21:00:37
Thank you all for your replies. So I guess all I have to do is measure the diameter of the hood frame, make something to fit, turning down the outside so that it will leave a capping on the top so as not to disappear down the hole I intend drilling through the ali capping and into the wooden frame. QED.
John Cooper M 628 |
5942 Posts |
MmmGee
135 Posts |
Posted - 18/06/2021 : 09:27:00
Something for a whole new topic is the variety of windscreen motor positions shown in Sam's photo of the line of M's. I counted at least 4 different locations! - that includes the option of not having one
MmmGee |
Edited by - MmmGee on 18/06/2021 09:28:56 |
