Mike Miles
90 Posts |
Posted - 21/09/2021 : 19:30:34
Wanted RH and LH brackets linking radiator to wingstay for NA, similar to photo below,
Hillebrand
131 Posts |
Posted - 22/09/2021 : 22:51:37
Hello Mike,
I can offer the wanted brackets. They come from my PA, which is converted to cycle wings.
They are numbered 2564 and 2565
Is 35.- GBP plus postage o.k. ?
Otto
otto |
Mike Miles
90 Posts |
Posted - 23/09/2021 : 08:59:30
Otto, Many thanks for your offer. I’m trying to check but my logic thinks the ones for the NA should be longer than those for a PA!! On the basis that comparing the tracks of 3ft 6in to 3ft 9in should give an extra 1.5in a side. Please bear with me whilst I check this out. Mike |
lordrob
Belgium
224 Posts |
Posted - 23/09/2021 : 09:05:27
Hello Otto, Have sent you a P.M. Rgds
lordrob |
2495 Posts |
Posted - 23/09/2021 : 09:14:16
I'm interested to see the studs at the wing end. Is this standard? I have bolts inserted from under the wings.
Hillebrand
131 Posts |
Posted - 23/09/2021 : 13:07:02
Mike, I'll wait and am looking forward to receiving Your reply. Otto.
otto |
Mike Miles
90 Posts |
Posted - 23/09/2021 : 14:09:48
Otto, My understanding is that the N type mounts are indeed longer to cater for the wider track! Thank you for your help, I’ll keep looking. Regards, Mike |
AVBowden
68 Posts |
Posted - 23/09/2021 : 16:36:11
Mike The NA brackets, part Nos. 3050/3051 are curved and don't have the side lug. Mine measure nominally 4.5" between headlamp mount and radiator fixing hole and the overall length is 7". I suspect the extra width is in the radiator rather than the brackets. Studs were the original method of attachment to the wing.
Hope this helps. Andrew NA0256 |
2495 Posts |
Posted - 23/09/2021 : 21:04:37
Thank you Andrew.
Hillebrand
131 Posts |
Posted - 23/09/2021 : 21:39:14
Now sold.
otto |
Robin Macmillan
415 Posts |
Posted - 24/09/2021 : 11:09:39
Mine were always studs
PB 0527 |
