Triple M Register Forums
 Fuel Filter MG Magna.
Author  Topic Next Topic
graham3647
Posted - 18/10/2020 :  16:32:56  Show Profile
Iíve installed an in line fuel filter in the fuel line to the SU pump but originally the car had a Malpas fuel filter installed after the pump. Fitted to the firewall.
Iím now thinking that the after pump installation maybe a much better idea?
Is there a right or wrong way? I had an inline filter fitted to my J2 for many years without issue.
Thanks, Graham.
Posted - 18/10/2020 :  18:48:51  Show Profile
Always fit the filter AFTER the pump. Should the filter become blocked the pump will struggle to overcome the block and possibly burn itself out. Fitting it after the pump, the pump will simply stop pumping and do no harm should the filter become blocked.
PA1169, 2M1281
graham3647
Posted - 20/10/2020 :  10:30:01  Show Profile
Hello Lew,
Sorry about the late reply and yes Iím pretty sure that you are correct. Someone else has made a good point. A filter before and after the pump is also a good idea. Apparently teatime is exactly what is installed on modern cars.
I canít see any reason why not?
Cheers #127867;
sven
Sweden
Posted - 20/10/2020 :  10:45:52  Show Profile
I agree with Lew.
NO filters before the SU pump.
Sven
roger cadogan
Posted - 20/10/2020 :  11:59:53  Show Profile
Don't overlook the fact that an SU pump has an effective filter on the suction side built into the body and accessed via the hexagonal nut at the bottom of the body. Of the many pumps I have rebuilt over the years, those that have operated with a dirty fuel system would seem to demonstrate the effectiveness of the of this inbuilt unit. As for a blocked addon filter on the suction side causing pump coil burnout, would the cars performance owing to a weak mixture cause an obvious problem before the pump stalled because of a suction blockage?
Roger
   Topic Next Topic
Triple M Register Forums © 2003-2020 MGCC Go To Top Of Page
