Can anyone advise where I might obtain a front engine support for a F2 it looks a bit like a Bonio biscuit I have been told but not sure the J2 one fits and has the advantage of elongated holes which should aid adjustment of the radiator. Many thanks, Bob
Hi Bob, I can confirm that front-end mounts are the same across the D-type, J-type and the F-types. However, I wasnt aware of any difference nor elongation on the J-type one! May have been a user-modification ... but yes can indeed ease radiator fitting.
Thanks Chris, I have seen one with the oval holes and also with a longer web for strength underneath, makes sense as I know of two broken ones. I will keep looking although I suspect most 90 year old castings will be equally suspect. Should you hear of one ? Appreciate your assistance. Bob
